Wish i had known that was what i could do Jim... But none the less. I drilled n tapped the valve cover. Not much oil gets slung round in there, compared to the block/case, and what lil bit that 'may' make its way in the fitting, will drop back down cause I drilled lil holes(4), in the side of the inlets threaded area, which will cause any oil that makes it to the main opening to drop back down instead of being sucked up inside.
With this pump ill be able to move my tank to the other side of the motor, n equal out the appearance n area of items on my rearend(everything is on the left of the motor... Tank, TC/CVT, JShaft, axle gear, brake).
