Increase speed from 40 to 80mph
mzg
How can I get my kart to do 80mph? Now it does 40, what is the best and or the easiest way to get it to do 80, Thanks.
slideways
Seriously? why do people ask such stupid questions... how about an airplane runway and a 20t axle sprocket? May take you a few hours to get up to speed but you'll hit it eventually. If your $14 lawn tires don't blow out, and your simple steering setup can keep you straight, and your brakes work, and you can see from your eyes tearing up...
mzg
No such this as a stupid question don't need for your smart comments you can just keep it shut and not reply at all. Not everyone is a smart a$$.. & have you ever heard of a helmet?
slideways
Lol... at least they'll recognize your face in the casket. Why is mph so important? Most of the people on here don't even understand how an engine works inside let alone how to make your kart go faster. Its all backwards.
mzg
I just wanted to find out ways to get it to go faster, thats all, 80 was a number pulled from my head no reason to get it to go 80. What speed do race karts go at?
DirtTrackRacer_07
DeeR SlayeR
tennessee
wat the world lol
What all do you got to work with.
We need some information and some pictures please.
How easy is it for you to find parts and how much do know about working on go-Karts?
Kenny_McCormic
Kartless....
Michigan Troll
Race karts top out anywhere from 50-60(6.5 clone class) to 160 (250cc superkart)
At those speeds A LOT of stuff needs to be tiptop or you WILL die. Going 80 on a yard kart is like 200+ in a car. Tires, wheel bearings, steering linkages, front end components, brakes, etc.
The_Machine
GA/AL
I want my kart to fly to the moon. what type of tires should I get? The lightness of my hollow skull and my 3.5 tecumseh should do the trick.
mrfreyguy
Buggy Almost Done
Iowa
I guess if your serious about going 80mph just get a race kart chassis and a bike engine.
danjwant
Norwich, UK
Going 80mph on a homemade Go-kart would take some serious precision engineering and I don't mean to be stereotypical but If you're new to welding, building an 80mph Go-kart will not be easy for you. My kart can hit 45mph (+/- a bit) and that runs on an unlimited 50cc ped engine. The frame is very strong, steering is solid and 45mph, 4 inches off the ground is very quick.
By all means try and build a fast kart, but make sure you have a decent bike engine, as the typical 13hp motor won't take you that fast. Also learn how to weld properly and you'll need to weld strong for that speed, and make sure you think all you plans through as this could be one seriously dangerous kart.
And also post some pics of what you've got/ what you plan to make.
fowler
Bullsbrook West Aus
get a race kart frame and strengthen it to hold a v8 then super charge it then u will go fast assuming u stay upright or staight
(i spesaliae in silly ideas)
but on a seriouse note danj is right this is serious speed for a race kart
if u want that speed then get a buggy
danjwant
Norwich, UK
V8 Supercharged on a homemade go-kart, lol. MZG, you say your kart does 40 MPH already and may I ask, is that not fast enough? Some people struggle to hit 15, so 40 is very respectable. Besides if your kart hits 40mph max, doubling that will be almost impossible with the same engine. You'll need a new engine, or you'll need to upgrade and tuned everything else perfectly to go faster, however 80 is pushing boundries a little to far I think.
Buy a small car I say and there's your starting point.
:worried2:Wow. 80? Mine'll do 45 flat out and wide open, and that's a little hairy. If I did 80, they'd be picking me up with a Shop Vac and a squeegee!!!:roflol:
KieranM
Doin It!!
Kilkenny, Ireland
i know of a vw polo that cant even reach 80mph, its a 1ltr so i dunno why you want to reach past 40, ideas like this are why so many people are against kart/ bike building
r97
Measure twice cut once
Massachusetts, USA
your never going to reach 40 if your in some 2 person yerf dog those things struggle to get to 30 if you want the potential of 80 and the ability to reach it in under one hour get a racing kart and motorcycle engine, plus please now your way around an engine, i've almost cried when people ask how to remove a gov, and then after you tell them how (even though theres 300 billion vids and a sticky showing you how) they ask where the block is :mad2:. and please if your reaching above 40 quality steering, wheels, tires, BRAKES, welds, design, and ware a helmet!!!!!!!!!!!!!!!!!!
danjwant
Norwich, UK
One quick thing guys, how do you remove the gov... :wai:.
In the nicest way possible, I suggest you dump the 80mph idea and stick to 40-50mph max. Good luck though.:roflol:
