Idle way to high!
GXMATT
Mini Kart Guy
uk
have fitted my gx200 to my mini kart, INSANITY el rapido! the only problem is it idles high and the clutch is engaging and smoking so i cant run it :( any help?
Kaptain Krunch
Pro Junk Collector
vermont
there should be a little screw by the throttle lever, try ajusting that.
Its not by the throttle lever, its on the carb. Right where the linkage goes to the butterfly there should be 1 set screw, then another on the side, the one on the side adjusts your jets, and the other one will adjust how far your butterfly closes. Adjust the jets first till it idles lower, then if its still too high try adjusting the butterfly.
GXMATT
Mini Kart Guy
uk
ok sounds good, i will have a look today but could you perhaps put it in more simple language.
GXMATT
Mini Kart Guy
uk
*cries* i have located all the screws but i have a problem :(. the small black plasticky thing does not close fully. when i poke it back it idles perfectley. what do i do now? thanks for the help so far (Y)
Kaptain Krunch
Pro Junk Collector
vermont
Probably just a bit gummed up, spray some wd40 on all the moving parts in the throttle linkage, then wipe off the drips and try again.
GXMATT
Mini Kart Guy
uk
still no good, ive decided to disconnect the govenor. use the gov rod to attatch the black twisty thing directly to the throttle lever. would this work?
GXMATT
Mini Kart Guy
uk
i have done it, it works well and now i have no govenor, just keeps revvin! had to much power as it was. i think i will restrict it via the throttle screw. i dont have to anything to the govenor screw do i? it will be ok?
GXMATT
Mini Kart Guy
uk
the vidoes really helped! i removed the gov gear and i was re assembling my engine....then snap. i snapped a bolt holding the crank case on. THE LAST BOLT!!! i dont think i have used so much obscene language in my life! so tomorrow is the tricky biz of removing that bolt and replacing it! :oops:
GXMATT
Mini Kart Guy
uk
yeah your right, i was using a socket set, ripped all the skin of my knuckles. last of my worries. Grade 8??
