idle issues
bbdinnc
PBO NC
Tecumseh OHH60 (6hp) will start (with starting fluid) but will not idle, new carb and air filter, new gas tank and gas. any ideas out there of where to start?
DirtyDamage
Westminster Colorado
If you open the throttle a little and start it will it stay started?
I would try to open up the idle speed screw a little. Probably came fully closed and isn't letting any gas in! Also, new fuel line? May be something as silly as no gas in the bowl, or a shorted out kill switch(lol)
XXXStevemanXXX
Astoria, Oregon
Well the number 1 rule is - ALWAYS hold the throttle plate ALL THE WAY OPEN when starting the engine. I do it on every kart engine and they will start first pull. I dont know why people will pull something 10-15 times when they could open the carb and it will start first pull.
Did you use new gaskets to seal the carb to ensure no air leaks at the intake? If you take off the air filter, will it idle? If it does, your carb is feeding too much fuel and the filter is starving it too much.
Its not his kill switch because it wants to run on starting fluid, meaning the ignition is working fine.
bbdinnc
PBO NC
well I went the cheap easy route and changed the kill switch and now it runs. now on to replacing the brakes and clutch. she goes just fine it's stopping her that's the issue now
bbdinnc
PBO NC
oh and thanks for all the suggestions when I get it stopping and going i'll take some pics cause she's a piece of work, my daughters picked out the colors and fabric for the seats
