Well the number 1 rule is - ALWAYS hold the throttle plate ALL THE WAY OPEN when starting the engine. I do it on every kart engine and they will start first pull. I dont know why people will pull something 10-15 times when they could open the carb and it will start first pull.
Did you use new gaskets to seal the carb to ensure no air leaks at the intake? If you take off the air filter, will it idle? If it does, your carb is feeding too much fuel and the filter is starving it too much.
Its not his kill switch because it wants to run on starting fluid, meaning the ignition is working fine.
