Russ2251
AZUSA:Powered by LAWN-BOY
Mistake I made was pipe lacked support and cracked under strain of it's own weight.
You have a choice between a resistor and a non-resistor plug.
RJ8C resistor or J8C non resistor manufactured by Champion is what is called for in factory specs. I always lean toward the non resistor types as they tend to produce a hotter spark.
The J19LM will work but is on the hot side and I would avoid using it under a load for extended periods.
That is probably correct. Is this a diaphragm carb?I'm thinking the needle and seat might be stuck ?
