Idea on 10Si drive force
88s10Durango
Chilliwack BC Canada
Hi all , on my soon to be Off Road kart , I want to run a 12 volt system with a decent battery for lights and my winch , can`t run a belt off the main axle as if the belt were to break or need replacing then I don`t want to have to dismantle the whole CV axle and main axle to put a new belt in ! So I`mtoying with the idea of making a small separate jackshaft with a small sprocket to run on the underside of the main driver chain somewhat like a tensioner , then the proper size V-belt pulley on the shaft to drive the 10Si , only problem with this I see is it won`t charge until the kart is actually moving , I need a good 12 volt dc system though as my engine only has a weak 6 vdc 3 amp charge stator and I have a 2000 lb 12 vdc winch I will be mounting on this kart . Any thoughts to this , I`ve checked on changing out the stator but a $ 50 jackshaft compared to a used stator , regulator and such >> $ 400 is why I want to try this .
heres a some what of a pick with my idea ,:cheers2:
Sounds pretty doable. Sure, it won't charge until you're moving, but you'll be doing a lot of moving, right???
You might have to fool around with the ratios a bit to get the alternator spinning in an acceptable speed range.
anderkart
Surprise Arizona USA
The 10si will spin easily until its charging, then how much h/p it takes to drive depends on how high of an output level it has and your pulleys gearing ratio.
I used to rebuild these alternators everyday for a living. Unless you've got a high-hp engine, I suggest you get a lower powered 10si thats been bench tested to have a 37-amp max output.
Depending on what Stator/Rotor was used in your 10si the last time it was rebuilt, it could gave a max output rating anywhere between 37 to over 100 amps. The max output rating stamped into the alternators case is meaningless if the parts inside have been upgraded, so you'll need to have your alternator tested to be absolutely sure.
A 37 amp 10si would need to have its shaft spinning at 3000 rpm to achieve max output. If you use a higher output 10si you'll find more info here: http://oljeep.com/gw/alt/edge_Alternator_Theory.html#Section_2
An good alternator rebuild shop will have 10si pulleys ranging from a small 2-1/2" diameter up to larger sizes available to help get it spinning the right speed.
But to answer your question:
My rebuild shop had an Alternator test bench equipped with a 5hp electric motor to spin the Alternators. When I would build a special 100 amp high-output 10si, It would nearly stall that 5hp motor... Even a 65 amp 10si can take 3hp to drive to its max output, that's why I suggest you get the lowest output 10si you can find. A 37 amp model would probably only take 1 to 2 hp to drive to its max output.
Even with big driving lights, you probably wont ever need more than a 30 amp alternator anyway. And if your battery is really low on charge your alternator will be charging at its max output even without the lights turned on. But then once the battery's voltage got back up to around 14.2, the alternators output would taper off to 0, and not cause much of any load on your engine.
Oh yeah, If you get a 10si that's equipped with a self energising regulator, you can do a simple 1 wire hook-up between its output post and your battery's positive terminal. (w/10 gauge wire) Otherwise you may have to wire up those 2 terminals on the alternators plug, although that's no big deal either.
88s10Durango
Thanks guys , I do agree with ya on the 37 amp Hp requirement , my engine is a 1984 Yamaha TT 600 cc rated at 45 Hp @ 6500 Rpm so it`ll have enough get up & go to supply it, I`m going to run 2 50 watt driving lights , I have a 24 series Auto battery with 535 CCA , my concern is just to keep this battery fully charged so in the event I need to use my winch it`ll have enough juice to run it , the winch has a 1 Hp draw at 12 vdc ( 800 Watts ) so the battery should have enough juice to have a 1 time use on the winch before being recharged again .
http://www.canadiantire.ca/AST/brow...%2Blb%2BMulti%2BPurpose%2BWinch.jsp?locale=en
The kart isen`t going to way alot , I want to build it around I believe is Theo`s design and add a roll cage
anderkart
Cool, sounds like you'd be just fine using any alternator with that engine. A deep cycle battery would probably be the best choice for winch operation but a conventional 535 CCA auto battery would probably operate your lights and occasional winch use for quite a long while even w/o a charging system.
88s10Durango
Yah that is my thinking also oh and my battery is a Deep Cycle Marine battery rated at the 535 cca , hope to be picking up the metal for the frame in a month , shooting with the 1 1/2" X .90 wall square tubing , I don`t have a pipe bender lol.
