I Think something is missing...
AlphaRunner85
Hendersonville NC
My roomate and i just set up a cart w/ a 5hp b&s....
and the clutch appeared a little loose on the drive shaft.
so after a few laps at the local dirt road i checked the drive shaft and it had been worn down perhaps as much as 1/8" and now has a nice clean taper to the last 2". did this compleatly trash the drive shaft and was there something missing.... :huh:
gocartkid
Bad Attitude
CT
Sounds like maybe a keway was not there, or the set screw was not there. Either wasy it appears the clutch "walked" on the crank. Post up a pic of the damage...
And btw, welcome to the site!
AlphaRunner85
Hendersonville NC
Well... the keyway and key were both present as well as the set screw, BUT the outer drum on the clutch seemed REALLY loose.
:huh: and the clutch would engage just after pull starting it
PICS
jr dragster T
Cold place
Whoa! I dont even see how a clutch can do that to a crankshaft! The shaft is not 100% ruined but it is a bit rough. Anyone say DIY tapper shaft.:roflol:
AlphaRunner85
Hendersonville NC
OK so the cart was bought used and the clutch is well worn....
but because im new to the cart thing i dont know how worn exactly
the drum wobbles around the drive shaft like its supposed to be fastened somehow BUT its on how we got it which is prolly very wrong:mad2:
Russ2251
AZUSA:Powered by LAWN-BOY
Bushing requires lubrication at regular intervals. More often in dirty/dusty conditions. Excessive chain tension would also contribute to this as evidenced by statement "and the clutch would engage just after pull starting it.". Clutch was probably worn out to begin with.
