I started to build
for the kid in me
This is the first cart I have started to build any suggestion's?
I bought a comet cluch with a 5.5 honda engine nock off.
How many teeth should the rear sprocket have?
This is for my 16 teen year old girl.
kibble
I banned myself
It looks like you know what you're doing! Looking nice. :thumbsup:
As for the rear sprocket, depends on how many teeth your clutch has, your tire size and how fast you want it to go.
r_chez_08
Should be in the shop...
Cornwall, UK
nice!!! sprocket depends what you are using it for. offoad more like 12/70-80(high torque,lower speed. track karts more like 12/50(fast, less torque though)
jr dragster T
Cold place
I had the same front wheels on my kart at first and with the crappy bearings in them I would have the bearings killed in about 30 minutes of riding. I got sick of those tiny bearings and bought some high speed 4 bolt tappered rollar bearing hubs and 4 bolt 5.70" X 8 trailer tires.
for the kid in me
I shopped at princes auto they didn't have any good front bearing set up I thought I would give these a try.
were did you buy the hub and tires for your's
THE_SHRUB
Fantasmatissist
ya i used the exact same front wheels from princess auto cept we used them for all four corners, first run out we popped a tire, third run out we blew a bearing housing... so now i have to rethink pretty much the entire drive train...
for the kid in me
I have a 10 tooth cluch and a 48 tooth rear sp.
I should go with a bigger back sp for off road is this right?
I think I will try your calculator just noticed it thank's
for the kid in me
yeah that would be pretty disapointing if that happened first time out.
I did see PA had a hub and spindal all ready made but they were $ 60.00 for one I was just trying the cheap way out
minibugger
Fraser Valley BC Canada
You might want to check out www.casterland.com for all you Canadian guys. They have a good selection of wheels, wheel hubs and tires in stock. got my front tires for the Dingo there at $ 26.00 ea. Good online catalogue with pricing that appears more reasonable than PA.
r_chez_08
Cornwall, UK
on my offroad setup, i am using 16:93 with 14" wheels. (#219 chain)
depends on the size of your back wheels. depends what speed and torque you want (smaller back sprocket/ bigger wheels= higher speed, lower torque nd vice verca)
robin
in a house
nut if i remember right you are havving az bike engin so you have to take the primary reductions in the gearbox in to acout as well
big rob
PA wheels
What I have done in the past is remove the cheap
low speed bearings , and replaced them with a comercial
sealed roller bearing , take your rims with you and they
can measure them .Its been a while but the last ones I
got cost $6.00 a piece and worked great.
Look in your yellow pages under bearings, most of thease
places also sell chain, sprocket, etc.
Rob.
for the kid in me
Got a little more done.
never changed bearing yet in front end. Haven't had time to check out bearing places yet.
for the kid in me
more pic's
more pic's
