I REALLYYY want this EFI engine..[[852cc Vtwin w/ EFI]
FreeRunner15
It would be PERFECT for a boosted setup.
90° V-twin
-Integrated electronic governor
-Pressurized lubrication system ( What is required for a turbocharger)
-Electronic ignition with variable spark timing
-Automatic compression release
Sequential multi-port fuel injection
Compact electronic control unit .(the ECU)
High pressure fuel injection technology with electronic fuel pump
Cast-iron cylinder liners (good)
Metal engine cover with integrated clean-out ports
Specifications
Displacement
852 cc (52.0 cu. in.)
Number of Cylinders
Bore x Stroke
3.33 x 2.99 in. (84.5 x 76mm)
Compression Ratio
8.2:1
Oil capacity w/filter
2.5 U.S. qt ( 2.4 liters)
Maximum Power
29.5 hp (22.0 kW)
at 3,600 RPM
Maximum Torque
48.3 ft lbs (65.5 N·m)
at 2,600 RPM
Dry Weight
131.6 lbs (59.7 kgs)
http://www.kawasakienginesusa.com/engines/fx/fx850v-efi
Well go out and buy it Mr new and improved....
It's a vert engine though..... Oh I forgot... Your also an expert in those conversions too...
From names to vert engines.... I wonder what's next...
FreeRunner15
Microsquirt is a good option for a small boost aware EFI system.
$330 for the ECU+8' harness
$270 for the module.
http://alchemyautoworks.com/ecu-tuning/megasquirt/microsquirt/microsquirt-ecu/
I'm guessing it gets tuned with MegaSquirt software and a laptop.
very pricey.
I definitely will not be going through with all of this. Still an interesting piece of knowledge though.
If the engine, microsquirt hardware, and all the forged goodies were just laying there for me to use Then I would do it.
Flyinhillbilly
The great cornholio
North West Arkansas
The software is free. Msefi.com will answer any questions you might have about it. It will work with a single motorcycle throttle body and fuel injector if you want it to. I believe it can even control the timing. All you'd need is the microsquirt, and a short harness and the individual components to make it work on a go kart. DIYautotune.com is where I got all of my megasquirt stuff.
As long as you keep it dry, a megasquirt 1 would handle all your fuel injection needs on a go kart and be much cheaper.
