I got an old engine, Power Products Corp.
Clayton
Saskatchewan, Canada
Sorry I was wrong, I started rebuilding the carb, I looked at the top of the float bowl when I saw these words embossed on it "Tillotson Made in Toledo Ohio". Jackpot!!! well not really, but it is a tilly. And Russ, the size of the bore on the carb is bigger than the DB30 2.8hp carb by a tiny bit, so wouldn't it work?
Russ2251
AZUSA:Powered by LAWN-BOY
Bore size is (somewhat) immaterial. Venturi size is important as is jetting.
The Tillotson badge does not necessarily make this a better carb than what B&S may use.
Quite possibly this exchange will be a backwards step.
Clayton
Okay, well, I won't be puting it on an engine for a while, and I am planning on getting a 3hp Briggs for testing carbs and stuff so once I get a test engine I will check it out and see whats up.
Bluethunder3320
you could always just try it.
you never know.
unless you have to weld up an entire custom intake manifold and everything...
