Bosch
I believe there is a minor disconnect going on between exchanges. But I'm having a pretty good time seeing how these engines work, so I hope people will continue to play along.
In my example, pretend that I have the rocker arms removed. So with valves not moving, the piston is free to go up and down and there is no defined compression or exhaust cycle. True?
BUT... when I line up the dots, & I have the piston at top dead center, and I set the rocker arms in place, that is defining and establishing the compression stroke, yes? if I followed those steps in that order, is it possible to get it wrong?
