Thepartsguy
- Messages
- 1,443
- Reaction score
- 1,306
Where to start a weird Briggs! But the best kind of weird! So they took a standard tiller coolbore crank at the factory and they just stuck a sleeve on the crank and pressed a bearing over the sleeve and stuffed it into a flywheel side I/c bearing block. Genius! They only did this on 80’s reduction I/c 5hp’s though. So that means now that I retrieved the sleeve off the reduction crank I can convert this reduction 5hp I/c to a standard 3/4 crank. Then I’ll hunt down a bearing sidecover to make a duel crank bearing I/c block. then comes the billet. A lot of billet.. Finally a worthy base
But I was hoping to avoid that. You write well.
