I burned up a cluch in two days? help?
Zane
Destroyer of Clutches
Atlanta, Ga
TL;DR at the bottom, I tend to ramble and jumble up my thoughts, read the body for all the info.
I'm not 100% sure what's wrong here. My current gearing setup is a 6:1 ratio on 13 inch tires. We ride in the street and off-road but none of this is trying to do a hill climb, it's flat for the most part. I also have a high-flow intake, upgraded fuel jet, and high-flow exhaust.
So I just removed the governor and set up a direct linkage to the throttle butterfly valve on the carburetor. It pushes and returns like it is supposed to and when at idle the arm rests against the idle screw correctly.
My uncertainty lies with whether this is due to poor idling with the governor off or most of the wear happened before the governor removal. This clutch is maybe 2 weeks old and was a $40 max torque "SS" clutch, not a knock-off (preset to engage at 2200rpm).
With the governor first removed, the gokart sat still at idle with not movement. I slowly noticed it wanting to kind of lurch forward but would more of rock back and forth slightly due to the weight of the kart and chain tension pulling the opposite way on it. Now the gokart will actually try to run away (very slowly).
Am I looking at a gearing issue? Someone on reddit suggested that wouldn't be the case since I have a 6:1 setup. My current tires are new and larger than the old ones but not by a massive amount. I can always drop the idle to the engine just barely being on but I'd rather rule out other things first.
TL;DR: Clutch just burned up in about 2 days, recently removed govenor and got slightly tires, also installed intake, larger fuel jet, and exhaust. I'm unsure what killed the clutch and don't really want to shell out $40 more to just burn one up again.
Zane
Atlanta, Ga
Tires are 13 inches. Front's tires I'm not sure of the exact measurements but are smaller. 60 tooth sprocket, 10 tooth clutch. #40 chain I think.
Here's an imgur album with pictures of the setup. http://imgur.com/a/DCYKD
derrick81787
Southern Illinois
Hi Zane,
People here like pictures (it really does help with diagnosing problems), but something else seems off. When we talked earlier, you linked to the kit that you bought which I thought included 13 inch tires, but I might have read wrong. Then you mentioned getting up to 35 MPH top speed. With the governor removed, a 6:1 gear ratio, and 13 inch tires, I thought that sounded plausible. But this post says 6 inch tires. Sorry if I misunderstood earlier, but I don't think that getting 35 MPH with 6 inch tires sounds possible. Maybe someone will correct me, but 6 inch tires with a 6:1 gear ratio (10T sprocket and 60T axle sprocket is what you said earlier, right?) running at 5400 RPMs (just a guess, but in the general ballpark for a Predator 212 with no governor) tops out at 16 MPH according to the speed calculator I'm using. Are you sure you have 6 inch tires? It's the outer tire diameter that matters, not the rim diameter.
Anyway, people here know more about this than I do, but tire size is really important to the answer to your question. The difference between 6 inch tires and 13 inch tires is pretty big.
derrick81787
Southern Illinois
It's not a problem. Someone here will be able to help. Actually, the fact that someone said that 6:1 sounds ideal when your post said 6 inch tires takes me back to the idea that maybe it actually is a gearing issue since in reality you have 13 inch tires. I'm still a little new to this and don't have the best feel for what gear ratio is best for what tire size, though. All I know is that I had a kart with a 9.36:1 gear ratio with 16 inch tires, but that was used off road and was probably geared lower than what would be necessary for a basic yard kart.
Zane
Atlanta, Ga
I have not. I read that you should oil for every 2 hours of operation and I have ran it maybe 5 hours. I wouldn't think this is what killed it so quick but I'll try harder to stay on top of that. Would oiling it possibly free the clutch? It doesn't take off at idle near as hard as the last broken clutch did.
Staff Murderator
My brain processed the 6 inches figure to mean the size of the wheels in diameter, not the tires. It was automatic.
Go back and read my link from BMI. Excessive idling and no clutch lubrication can and will roast your clutch as well as half throttle driving where the clutch is not fully engaged but it's slipping. There's other key information there as well.
Zane
Atlanta, Ga
I actually read that when replacing my clutch in the first place and just let lubricating it slip my mind... I guess I'll buy another and lube it and literally never idle.
Do you think my gearing setup will be okay though?
Staff Murderator
If the clutch is not heat damaged all the way through, you might be able to free it up with some lube (WD-40/penetrating fluid) like FHB says.
I'd say when it's hot and "burned up" right after a karting session, that's the moment when it's at its worst. Let it cool down, take it apart if possible and inspect for damage or galling on the clutch drum and shoes... Depending on the condition, you may be able to rehabilitate it.
Some interesting videos:
https://www.youtube.com/watch?v=htE8-IcFcxU
https://www.youtube.com/watch?v=77Giz2mL_tw
Flyinhillbilly
The great cornholio
North West Arkansas
I'm kind of a hack when it comes to my minibike, that said, a lot of times when mine is acting stupid I just hose it down real good with chain lube and carry on. It'll smoke like crazy and slip for just a bit, then I'm good to go again.
Once again, this is not the right way to do it, but it works for me.
Zane
Atlanta, Ga
Okay, thanks guys! I planned on attempting to free it or see if it's damaged before buying another. Hopefully all it takes is eliminating idling completely and greasing the clutch religiously.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Well what is Destroyed? the actual clutch material (shoes) or the bushings?
A misaligned chain, or chain too tight, or crappy chain with tight links will also destroy the bushing, prematurely to the actual shoes.
Poboy kartman
Senior Moments Member
White Settlement Texas
Some random thoughts:
First: Let's be clear on this. Centrifugal clutches are designed to endure idiling from fill-up to tank emptying without issue. It's what they are designed to do and are perfectly capable of doing so...IF!!!!! ...the idle is low enough that they completely free-spool as designed.
If the idle is high enough to PARTIALLY engage the clutch, then friction will build heat very quickly. IMHO ...this was your problem.
(Is it just me? ...or does anyone else think a kart shouldn't lurch at idle....or ESPECIALLY take off?)
Should die, right?
I could be wrong, somebody said I was once...but we're divorced now....my two cents.
Edit: Oh yeah...I forgot to mention until Chancer reminded me....jack the kart up and make sure the wheels and everything spin freely....should be very little resistance.)
---------- Post added at 07:11 PM ---------- Previous post was at 07:00 PM ----------
There will be some nice young men in their clean white coats coming to see you very soon....HA HA HO HO HEE HEE!!!!
Honestly I think it's a bit of a misnomer of calling it a burned clutch... ....
If it welded itself shut then is say there is a "burning" involved...
If anything the thing got hot, then enough later that the spring lost its proper temper and now engages at idle after being stretched...
Poboy kartman
That's great info!...........but....ummm....WHAT CAUSED IT?:lolgoku:
