Zane
Destroyer of Clutches
TL;DR at the bottom, I tend to ramble and jumble up my thoughts, read the body for all the info.
I'm not 100% sure what's wrong here. My current gearing setup is a 6:1 ratio on 13 inch tires. We ride in the street and off-road but none of this is trying to do a hill climb, it's flat for the most part. I also have a high-flow intake, upgraded fuel jet, and high-flow exhaust.
So I just removed the governor and set up a direct linkage to the throttle butterfly valve on the carburetor. It pushes and returns like it is supposed to and when at idle the arm rests against the idle screw correctly.
My uncertainty lies with whether this is due to poor idling with the governor off or most of the wear happened before the governor removal. This clutch is maybe 2 weeks old and was a $40 max torque "SS" clutch, not a knock-off (preset to engage at 2200rpm).
With the governor first removed, the gokart sat still at idle with not movement. I slowly noticed it wanting to kind of lurch forward but would more of rock back and forth slightly due to the weight of the kart and chain tension pulling the opposite way on it. Now the gokart will actually try to run away (very slowly).
Am I looking at a gearing issue? Someone on reddit suggested that wouldn't be the case since I have a 6:1 setup. My current tires are new and larger than the old ones but not by a massive amount. I can always drop the idle to the engine just barely being on but I'd rather rule out other things first.
TL;DR: Clutch just burned up in about 2 days, recently removed govenor and got slightly tires, also installed intake, larger fuel jet, and exhaust. I'm unsure what killed the clutch and don't really want to shell out $40 more to just burn one up again.
