I'm sure many, if not all at some point, contemplated duel engines. Yesterday I flipped my jack shaft gears. My clutch is a 12 tooth, gear in is 18, out is 12 and sprocket is a 60 tooth. I knew that flipping it to 12 in and 18 out I would lower my ratio and pick up on my overall speed. Took it for the test run and it was WAY to fast for the kart. Did think I was going to get it back in one piece! Needless to say, IT WAS FRIGG'N AWESOME!!! Thought I was going to pinch a hole in the seat with my butt cheeks. On the down side, I could barely make it up my drive way. Also something I was expecting.
Now my theory- if I were to run duel engines with jack shafts with different gear ratios, wouldn't the higher ratio jack shaft setup provide the launch and the lower gear on the second engine to provide the top end speed.
On my kart I have a non modified predator. If two non mods were used, the governor would kick in on the launch side once max RPMs were reached. I'm assuming this wouldn't cause any drag per sa at faster speeds.
Am I delusional or is this phesable?
