B man
Tecumseh FTW!
Husqvarna help!
Well my shop teacher heard i can fix engines. so he brought me his old Husqvana weed eater. he said it sat outside for 3 years.
ok so first i put new fuel in. and tried to crank it. well it fires up runs at idle a while then dies. if you hold the throttle down and crank it it fires up revves up high then just dies. its like when ever i try to rev it when its idleing it just bogs down and dies.
so then i tried no air filter. same result.
poked the jets out. same result.
checked the diaphragm. well it had a tear in it but it wasnt that big so i went on.
blew through the jets and carb. same result.
by the way when i was working on it the primmer bulb would barely pull gas through the lines but when i revesed the lines it pulled gas fine. where they on wrong?(or maybe the right way?)
but even after doing that still ran the same.
so i checked the spark plug. it was still good. but the boot had water in it. i cleaned that but no change.
im thinking its that diaphragm. but could that really cause it to run SO bad?
what do you all think? its two stroke by the way.
