cheap_a__kart
For the cheap people like me I figured I would share what I did to strengthen hf wheels
First thing you do is take the rim apart... use a miny sluge to take out the berings try not to mess them up cause you will have to buy a new wheel
take a dremel and take all the paint off around where the bearing tube thing meets the rim on the front and back... make sure to take off some on the tips of the rim for the ground
put some nice fat welds on there
put the bearings back in with a socket or something close to that size so that you don't mess it up and spot weld that on
you have to make it short or you will burn out the grease in the bearing (don't ask how I know that)
and the finished product now you can be a lil harder on these cheap wheels and they won't blow out the bearings
oh and make sure you if you want it to look nice just throw some spray paint on those rims and say it is black chrome they will believe you don't worry
good luck
bake
good luck
bake
