how to remove a stuck set screw!?
That's what I have been doing, using a small bit first then going larger all the while using cutting oil, it just got to the point even brand new bits don't phase it... You can drill on it for 15 minutes and not make a scratch.
Then, I believe it has hardened from the heat. McKutzky suggested the torch thing, and I know you said you have no torch, but can you borrow one? We're not talking about an OxyAcetylene rig here, just a propane plumber's torch.
oldbikerarlo
Old guy
Marana, Az.
Allmost makes me think, that the threads are stripped and the drill is turning the set screw in the bottom of the hole, set screws are just not that hard. Drilling doesn't make them harder
Set screws are typically of a better alloy like strong bolts(grade 8) and are typically hardened/tempered. If the drill was just not hard or sharp enough to drill it out it would cause the set screw to be at least work hardened or if enough heat by that aswell. I have encountered this my self with some machines.
a propane torch will do but even a O/A torch will do, just keep the flame small and localized to the spot and none else.
kendelrk
redneck engineer
westland michigan
if its the key way screw that sticks up just a little, could you not take a jigsaw on the side and cut a slot and use a screwdriver on it? like a screwdriver drill combo
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
well guys i got the clutch off!! first i tried drilling it out, broke a few bits and said onto the next option. Which was heat. That didnt work so i tried grinding off the set screw. i ended up grinding into the shaft (woopsy :/) That still didnt get the dang clutch off. so i heated up the Whole clutch (i took off the shoes, and the plates that held it on so it was just the part that hugs the shaft) and then when it got really hot enough i started peeling back the metal . it worked till about halfway then i busted out the griner and finished cutting a line through it. grabbed the pry bar and after a few tugs i got the thing off. Just slipped another clutch on, mounted on my kart, and i was riding in no time.
Took about an hour and a half to get it off but i was able to do it. haha. Thanks for all the tips and suggestions guys!
fowler
Bullsbrook West Aus
cobolt drills bits are the way to go
they are a bit more (about $4) and u would never try and buy a whole set but they will drill out anything
they last forever though if u use oil when drilling
it is what i use when rusty bolts break
or left hand drill bits
