how to remove a stuck set screw!?
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
Hey guys, well I finally got around to changing the pullcord on the tecumseh 5 horse and it runs great. Only thing is the clutch is toast, and it blew apart when I was testing the engine. So I went to rremove it and I was able to get one off easily, but I had a hard time getting the other one off. It is stuck and won't budge. I've tried everything exept heat because of how close it is to the gas tank. I'm also scared because the screw is starting to strip on the inside. What can I do to get it off!?! I want to take the clutch off.
Sentrek
Carrollton, TX.
I have been tryingto drill out a set screw on one of my motors for 3 days, I have went through countless drill bits (cheapies from HF), some good ones I had lying around, and even went to lowes and bought some titanium? Coated bits that are supposed to last a lot longer and I still haven't made it through that set screw yet.....
dave1701
Good for 100,000 Miles
MICHIGAN
I agree that you must be doing something wrong if you are having that much difficulty drilling it out.
Bluethunder3320
i had a piece of a comet stick on a clone shaft once. it was loose but WOULDNT come off. got stuck right at the end. we tried filing down the end of the shaft and it still got stuck.
final resort: sliced it apart with an angle grinder.
Sentrek
Carrollton, TX.
3 Days? All day, every day, for 3 days? You're doing something wrong!
No, 3 days after work & dinner, seems like forever after driving-around buying drill bits ect.
I don't think I am doing anything wrong, I have drilled plenty of bolts out before, I don't know if being a set screw since it was so small that it was hardened or what but it's just tearin drill bits up.
it got hard by drilling on it. im thinking u will have to use heat. keep it smalish and watch where u point the torch. it will only need a small amount for it to be annealed to drill out. if the clutch is toast it wont matter if you heat that part of it.
Sentrek
Carrollton, TX.
There is part of the problem, I have no torch, not yet anyway. I ended up using a different clutch but would like to get this one of eventually to use on a future project.
yeabuddy!
is it like a seized bolt your trying to get out? if so, youre probably gonna be drilling for years unless youve got a nice bit, and a press. but if its a seized bolt you broke the head off, take a socket thats a size or so smaller than the bolt youre trying to get off, and beat it on the bolt as much as you can, then just try and break it loose. the 12 point sockets, or the star bit ones work best.
Sentrek
Carrollton, TX.
Have you tried letting the screw sit in penetrating oil overnight?
Yeah, I sprayed the hole full ad let soak about 24 hours in pb blaster 2 days in a row, I broke 2 Allen wrenches trying to break it loose. That's when I started drilling... Had I known t was going to be so difficult to drill I would have taken it somewhere to try heating it and breaking it loose first.
How large is the bit you're using? Maybe drop down a few sizes until you penetrate, and then work on opening it up? Remember to keep chuck speeds low, and cutting oil never hurts.
j.concepcion54321
East Providence RI
Tomorrow after school ill try heating it up, and removing it.
If that doesn't work then I'm probably just going to try drilling it out.
Quick question, instead of drilling it, could I just go with the angle grinder and cut down into that piece until its gone? Thatd be easier for me as all our drills are battery ones so they won't last a long time.
The clutch isn't salvageable, right? Go ahead and grind. Take it slow and easy so the heat stays under control, and you don't accidentally mangle the shaft.
Sentrek
Carrollton, TX.
That's what I have been doing, using a small bit first then going larger all the while using cutting oil, it just got to the point even brand new bits don't phase it... You can drill on it for 15 minutes and not make a scratch.
j.concepcion54321
East Providence RI
i could use the clutch on a different engine with a tapped shaft that i can inster a screw onto with a few washers to hold the clutch drum from falling off. Thats what im doing on my bros kart and its working fine. So if i can get the clutch off with little damage then id like to. Im gonna leave the grinding to a last resort cause i may damage the shaft so ill try heating it up and trying that, ill let you guys knowhow it turns out.
