i thought sprockets had keyway? the kit i bought has keyed sprockets, and the driven is keyed also, so dont you have to put collars on both sides of them? im sooo confused
most are 5/8" and keyed. to keep it from moving back and forth you need to use whatever your shaft calls for. It can be a c clip or wrist pin. usually its not a bolt unless yours has been homemade. If theres no holes or slots use a lock collar
its a 3/4" and it comes with one 3/4" collar so im guessing that is what i would use?
heres the link to the jackshaft kit i bought. http://www.mfgsupply.com/m/c/AZ1824-14.html
I use shaft collars on my powerwheels setup. Kinda wanting to get the split ones. Perhaps use a dremel to countersink the shaft for the set screws to limit side movement. I have a long 20 inch jackshaft on pillow block bearings.
