Russ2251
AZUSA:Powered by LAWN-BOY
Go to a reputable machine shop and show him what you have and what needs to be done. They do not charge for estimates.
well right before the cylnder there is a lip
it hits that
but i talked to the guy and he said it was normal and all horestman H beam stock length rods have to have te block die grinded
what is die grinding?
i jus dont want 2 take enychances with the flywheel
wait
how fast will a briggs motor run with:
hostman Hbeam rod, tilly HL 282 B carb, no govener, straight pipe, bushing side cover and stock cam?
Bushing sidecover eh? After 7000 you want to watch that. Starts starving for oil. Go n' get the EZ Bore kit to enlarge the oil hole.
wait
so with the setup here
i can easily use the stock cast iron flywheel without having to worry
