I bought a fixer upper go kart and realized my skills are a little rusty. After i replaced the clutch i realized the the rotor/gear on the back axle slides left to right upto an inch. When i removed the set screw i realized it wasnt sxrewing into the flat part of the axle.
I wanted to remove the axle and then align the rotor/gear so the set screw aligns appropriately.
Problem is i have no idea how to pull the axle.
Any thoughts
Thanks
Any thoughts
Thanks
to the forum!!
We need photo's to see what you're trying to describe; words only give us a vague idea. The more pictures, the better. The thumbnail format that the site software supports is also the preferred format, because many of us don't have the internet connections to support many of the third party photo sites....
If there is a flat that the set screw butts up against, but its not lined up, why cant you just spin the sprocket (gear as you called it) ON the axle till it lines up? Do you have a hex shaped axle? Or the normal round type? If its round, I do not see why you cant just spin it rather pulling the whole axle out......
