how did this happen?
Karts of Kaos
the many mowers guy
Wisconsin
There are no timing marks because the timing is non adjustable. I would do a compression test or leak down test wet and dry and compare numbers. You will probably find you may have to pull the head because the valves or guides are worn out. If they are you can bet the cylinder, piston and rings are too. Compression test numbers should be around 120. Higher or lower are a sign something is not right. A flat cam is another possibility.
wdym wet/ dry test. no oil?
