219 chain?? you sure...
if so 15 is already about the smallest toothcount you can get (I thought you'd need 16 to be honest)
Pitch is the distance between two adjacent rivets of the chain (center roller distance)
for a 219 that's 7.77 mm (very odd pitch, neither imperial nor metric match... odd but works well
imperial chain is easier
a #35 would be 3/8" (9.525mm)
#40, #41 would be 1/2" (4/8") (12.7mm
you see the pattern, right
first digit is eigths of an inch pitch.
Sooo.. the bad news.. 219 clutches are generally more expensive (uncommon chain on yard karts in the US)
uncommen to run a yard-kart-clutch on european race karts
(that commonly use 219 chains)
sooo while they are available, they're not the cheapest to get
if you clutch is toasted already.. you can safely buy a 90T axle sprocket
(I think I have sprockets up to 104Teeth for my kart which runs 11" rear wheels and 219 chain)
but, with 90T you should consider installing a sprocket/chain guard.
(that'd be ~9" outside diameter for the sprocket.. or 1" clearance on 11" wheels)
