Horrible takeoff torque
DaveW
Georgia
Hello everyone, I'm new here and need some insight. I've purchase a used gokart for my kids for christmas and the thing just has little to no hill climbing abilities with an adult testing. On level ground its okay but still lacks any real power until it hits a certain speed/rpm (which feels quite fast) and you can tell the clutch finally fully engages. The area I live in has hills though nothing severe or steep. It will primarily be used in offroad conditions on dirt trails in the woods. It has a newish HF Predator 212 on it with a Max Torque 10 tooth 41 pitch centrifugal clutch. The drive sprocket is 54 tooth 41 pitch on a live axle. The rear tires are 18's. It had a Hilliard clutch on it which I believe is toast. The guy I bought it from said when his kids used it they burned up quite a few clutches. Thinking I just needed a new clutch, I got the Max Torque, but this only slightly helped. It still struggles to climb up a relatively gentle slope. Obviously the clutch is smoking hot after a short ride. I've come to believe I've got some sort of ratio problem and/or I may need to be running a torque converter. They guy I bought it from mentioned that he thought the rear tires are not the original tires or size, meaning someone put bigger tires in the back. I know this could be throwing the ratio off it this is true. There is no jack shaft or anything on the cart, just a chain from the clutch to the drive sprocket. I know adding a larger drive sprocket would help my take off power and top speed is not my goal but I do wonder if a torque converter would better solve the problem.What gives me the better outcome? I hope I have given enough information to start. Thanks in advance.
Half-breeder
"Edit" button removed
5.4:1 ratio on 18"s?!?!?... Its a wonder you move at all!!!!
Youll want a TAV2 TC... Or replace the 54T for a 80T... Thats still pushin the limits at 8:1... but itll be 'better' than whatcha got now.
If you are looking for hill climbing, a TC is the way to go. With the 5.4:1 ratio and 18" tyres you have now, I am surprised you can move (like halfbreader says). That is an insanely tall ratio for those tyres. Either you need to gear to at least 7:1 with a centrifugal clutch, or gear to 6:1 with a TC. That means with a TC you will need a 60T sprocket, and with a centrifugal clutch you will need a 70T axle sprocket. You could also see if the TC on its own would make a difference, but it would perform better with a 6:1 ratio
DaveW
Georgia
Thanks for the responses guys. That's kinda what I had concluded though I didn't know what would be the right ratio with those size tires. I'm guessing the only other route other than changing the drive sprocket and/or getting a torque converter would be changing the rear wheels and tires out to smaller ones, right?
Thats correct. A 5.4:1 ratio is still going to be a bit tall though, unless your tyres are 10-11". Anything above that is still not going to be satisfactory for you
qtband
St. Louis, MO
You could also add a jackshaft assembly to get the gearing right. Especially if you're not looking for speed but torque. Plus, it's a lot cheaper than a TC.
DaveW
Georgia
I think I'm going to with a torque converter and see how that pans out with the 54 tooth sprocket that's already on there to start with and then go from there. It seems that most karts with the large tires in the back have a TC on it from the factory, so that told me something right there. I'm hoping it'll at least be acceptable for the time being and I can always make a few changes if needed after Christmas is over. I'm ordering one today and hopefully will have it installed sometime next week. I'll let you guys know how it turns out and thanks again for all the advise.
DaveW
Georgia
If you order the TC with a 9t sprocket, that'll bring your ratio back to 6:1
That's a great idea! Changing the axle sprocket appears to be quite pricey but this would be more cost effective way to bump the ratio without much trouble or cost. I've actually found a 9 tooth sprocket with a 5/8" bore and even an 8 tooth. An 8 tooth would bring me to up to 6.75:1 ratio correct?
As long as the bore of the TC is still the same size as your engine it will fit, and you are correct about the gearing
DaveW
Georgia
Umm, the sprocket goes on the jackshaft of the TC, not the engine...
That's what I was thinking. I know the Predator 212 is 3/4" bore but I'm pretty sure the bore needed for the jackshaft of the TC is 5/8". Looking at pictures of the included sprocket it appears to be a "C" sprocket, right? That's the ones with the hub on both sides and the teeth in the center. The 8 tooth sprocket has a built in 3/16" key. Does anyone know what size the keyway is on the jackshaft of the TC?
Here is a link to the 8 tooth I am looking at.
http://www.mfgsupply.com/gomini/gominisprockets/gominisprocketsdrive/gominisprocketsdrive58c40/az2182.html
DaveW
Georgia
Here's a quick update. Basically its dramatically better. I kept the 10t sprocket that came with the torque converter and performs wonderfully. It climbs hills now with ease with me driving (215 lbs ) so it'll do even better with my kids. I'm very happy with the results.
Yeah!!! :thumbsup::wai:
Thanks for the update, not many people are as considerate as you to let us know what the outcome was
