Hello everyone, I'm new here and need some insight. I've purchase a used gokart for my kids for christmas and the thing just has little to no hill climbing abilities with an adult testing. On level ground its okay but still lacks any real power until it hits a certain speed/rpm (which feels quite fast) and you can tell the clutch finally fully engages. The area I live in has hills though nothing severe or steep. It will primarily be used in offroad conditions on dirt trails in the woods. It has a newish HF Predator 212 on it with a Max Torque 10 tooth 41 pitch centrifugal clutch. The drive sprocket is 54 tooth 41 pitch on a live axle. The rear tires are 18's. It had a Hilliard clutch on it which I believe is toast. The guy I bought it from said when his kids used it they burned up quite a few clutches. Thinking I just needed a new clutch, I got the Max Torque, but this only slightly helped. It still struggles to climb up a relatively gentle slope. Obviously the clutch is smoking hot after a short ride. I've come to believe I've got some sort of ratio problem and/or I may need to be running a torque converter. They guy I bought it from mentioned that he thought the rear tires are not the original tires or size, meaning someone put bigger tires in the back. I know this could be throwing the ratio off it this is true. There is no jack shaft or anything on the cart, just a chain from the clutch to the drive sprocket. I know adding a larger drive sprocket would help my take off power and top speed is not my goal but I do wonder if a torque converter would better solve the problem.What gives me the better outcome? I hope I have given enough information to start. Thanks in advance.
