racingkartbuilder
- Messages
- 5
- Reaction score
- 0
just did racing mods and my engines not revving past 1000 rpm and idling at 800 have no clue what's going on the kart moves slow and then shuts off please help.
What is flyinhillbillys way I can't find it?From the sound of it all parts were added at once which can be nerve racking when things don't go as planned. Air filter and pipe alone would require the jetting to be looked at, which isn't mentioned or what the plug looks like.
You said you changed the flywheel, if it's an ARC flywheel the coil gap is different than stock. Somewhere in the .030" range and definitely worth checking.
Fuel pumps can be tricky due to flooding from overriding the float needle. Even if it isn't smoking from being rich, you should be able to smell the exhaust being overly rich. I'm tee'd off back to the tank with an inline shutoff about half way to overcome this, and I think Flyinhillbilly posted another method that's slicker than greased owl sh!t on a piece of ice.
Already mentioned are the timing dots lining up and the throttle linkage, and both a very plausible.
Converting mine to fuel pump shortly would like to know a few different methods incase mine floods
Thanks
