honda gx 240 6-1 gear reduction kart
No clutch on my engine I'm afraid, it's straight from an old cement mixer lol only had about 10 hours use from new
I see. Okay- it makes a bit more sense now why you'd go to the extra trouble. You of course need a clutch, that's why I asked. While these redux units often do have a built-in clutch, they sometimes don't.
mymumisaman
uk
Yeah would be nice if It had a clutch, iv taken the drive off to have a look and it's a cog on the crank linking to another cog to the output shaft , id have to swap the crank and side of engine casing to put a clutch on it and that would cost over £160 .......but saying that, I like a challenge and it gives me chance to try something new
mymumisaman
uk
update
Well I've been playing and finally sorted out the lever system that engages the whole thing :thumbsup: here's some pics,
It's not quite finished, still got to sort out the keyway and little bits and bobs .
mymumisaman
uk
Well when I get it together with the shaft I'll post a video , I still need to make some hubs for the wheels before I can test it under load, might get that done next week.
cool idea a belt clutch,
that all looks very nice indeed.
It should be mounted the other way around
- small rotor on PTO, large rotor on jackshaft -
otherwise you will have (eyballing) three times the rpm on the small rotor, and a hard job of gearing that down on the actual kart.
Still: I don't think that is the right material for this.
Wood is dissipating heat at a very low rate, wich makes it a good heat insulator, but in this case that is not a wanted feature ;)
especially not with this exact setup (large on pto) since the small rotor is turning really fast and will build up a huge amount of heat.
Anyways, good idea, turn it around and give it a try (not without making sand molds before) that way you can cast it in aluminum afterwards ;)
mymumisaman
uk
Well it works ..........just a little too well lol. Iv overlooked how the small pulley is connected to the shaft, and yes I am using threaded bar for the time being, but its 20mm high tensile stuff till I can get more funds lol, basically I need to make a keyway as the pulley is just spinning round the shaft, but it works!
mymumisaman
uk
I still need to make the hubs for the wheels that I plan to use but at least it works, just got to figure out what I want to turn it into...trike? Or kart?
I think I see a problem with that setup; the static position is disengaged & you need to actuate it to engage which means you'd need to hold the clutch in to drive & release it to stop :worried2:
Other than that, great work... until the wood wears prematurely... :)
mymumisaman
uk
I wouldn't consider that a problem, more of a safety feature:thumbsup: not sure how I'm going to set it up , either a handbrake lever kinda setup or hook it up to the throttle , so foot down engages clutch then throttle. I'm not having any gears so don't need a clutch pedal as such.
barney, ga.
I realy like your work, my hats off to you! The trouble as I see it is your gear reduction is wrong You already have 6:1 on the engine which is close as it is. All you need is a axle pulley slightly larger than the engine pulley with a idler pulley to clutch it. Your system has defeated the gear reduction box on your engine and your wheel speed is to fast.
mymumisaman
uk
I haven't negated the reduction drive just increased the gear ratio from a 6 to 1. To a 3 to 1
The engine is 8hp so should do the trick if not then I can always adjust the pulley sizes. it's. A case of trial and error as I'm still unsure of what I want to build and how heavy it's going to be. I've. Built a little kart before with a 5 hp 160 clone, it had a 5 to 1 reduction with a centrifugal clutch and pulled quite Well, so I figured bigger engine should be able to cope with less of a reduction. Dependant on weight of coarse. If not then it's an easy fix.
I guess there'd be no need to adjust pulley sizes, the driven pully sits on a jackshaft anyways, doesn't it?
Therefore you can simply adjust gear ratio with stock sprockets on shaft and axle, or am I missing something (again ;))
mymumisaman
uk
At the moment the engine is connected directly to the axle but if it don't work out then I'll put a Jack shaft on no problem
