Honda 150 GY6 prob when warm
SJshooter007
Hi all, first post here and I'm already got problems... :eek:
I've got a go kart with a Honda gy6 clone on it. Its 150cc and I got it from someone. When I first got it the fuel jet had debris in it, but cleaned that out. Got it running, but then idk what happened, but I ended up leaving it alone for 4-6 months. Finally, last summer got it up and running again.
Ran great the first couple times, but then I started to notice that it started decreasing power when it got hot. So much so that it wouldnt run even at full throttle and eventually died out. But when I let it cool and came back next day it would start right up no prob but then same thing would happen when it got hot. :mad2:
WHAT'S GOING ON?!?!
Things to note:
  • It's got a fuel filter(brand new)
  • Clean air
  • Fresh gas
  • Carb has a auto choke but haven't had problems before
  • Takes at least 5 mins before this happens. Engine has to get hot.
  • I took apart the carb today to see if the jets or any holes were clogged. No dice that I can tell.
  • All gaskets are oiled and sealed tight.
  • No hoses with holes
  • Clean spark plug(well, pretty clean anyways)
Thanks in advance for any help/advice!
First, I have seen failing ignition coils that will cut out when hot. However, the ones I have seen don't decrease and then die, they just die. But I suppose it's possible. Second- I can't help but wonder if you're overheating. Have you got enough of the correct grade oil in there? I'm not particularly familiar with that engine. is it a free-air engine, fan cooled, oil cooled? Third, you may still have a carb issue.
SJshooter007
It's got a cowling around the single cylinder and a fan on the crankshaft, so it's air cooled I believe.
Full of oil.
What should I look for in the carb? It's not fuel air mix bc that would mean it would run rough alot sooner. Right? I tore the carb apart today. Couldn't find anything! :(
Okay- it's "forced air" aka fan cooled. Make sure the fan is intact and operating properly, and that all fins and surfaces are clean. It may be full of oil, but is it the right oil? As for the carb, all I can possibly suggest is that it's dead clean and tuned to specs. I don't really think there's much chance it's the carb. Maybe vapour lock?
anderkart
Surprise Arizona USA
[*]Carb has a auto choke but haven't had problems before
[*]Takes at least 5 mins before this happens. Engine has to get hot.
Next time it acts up, take the air cleaner off, look inside the carb and see if the choke is open or if its malfunctioning (stuck-fully or partially closed). A cool engine will usually run ok for a few minutes with choke on, but not after its warmed up...
Excellent point, Anderkart- I dunno how the "auto-choke" coment skated right past me... :oops:
chrldo
check the petcock on fuel tank ,make sure you have good flow. these gum up just like carb. then check float level ,you might not have enough fuel in the bowl.
