SJshooter007
- Messages
- 3
- Reaction score
- 0
Hi all, first post here and I'm already got problems...
I've got a go kart with a Honda gy6 clone on it. Its 150cc and I got it from someone. When I first got it the fuel jet had debris in it, but cleaned that out. Got it running, but then idk what happened, but I ended up leaving it alone for 4-6 months. Finally, last summer got it up and running again.
Ran great the first couple times, but then I started to notice that it started decreasing power when it got hot. So much so that it wouldnt run even at full throttle and eventually died out. But when I let it cool and came back next day it would start right up no prob but then same thing would happen when it got hot.
WHAT'S GOING ON?!?!
Things to note:
Thanks in advance for any help/advice!
WHAT'S GOING ON?!?!
Things to note:
- It's got a fuel filter(brand new)
- Clean air
- Fresh gas
- Carb has a auto choke but haven't had problems before
- Takes at least 5 mins before this happens. Engine has to get hot.
- I took apart the carb today to see if the jets or any holes were clogged. No dice that I can tell.
- All gaskets are oiled and sealed tight.
- No hoses with holes
- Clean spark plug(well, pretty clean anyways)
