l0ll00l
So a while back, my friend and I took it upon ourselves to construct a vehicle out of spare scrap iron and an 11 HP Honda engine we removed from a pressure washer with a burnt out pump. I'm sure those of you familiar with welding will quickly spot my HORRIBLE welds, and nonsensical geometry of the bike, but I've since learned a lot, both in welding and engineering, so the next go-round won't be so bad.
We have recently decided it was time to completely re-build the bike, using a new design that we created, that will be notably stronger and less awkward looking.
Anyway, I will let the pictures speak for themselves, but will be keeping a thread(likely this one) updated with the new construction that we plan on starting this Saturday the 14th if anyone shows any interest.
Also, the bike is capable of roughly 49 mph. While testing the bike, someone felt it was necessary to call the police and report "A strange vehicle making a racket on their street." Haha. The cop was actually one of the very few down to earth officers I've met, and after closely inspecting the bike, told me he would be willing to clock my speed if I wanted. I think he was more interested in it than I was!
Picture of some of the first welds on the frame rails.
Rear view of the completed frame. We happened to have an old bike lying around, and promptly chopped off the front end, as I was not particularly looking forward to designing a proper front end at the time.
You can also see the brake rotor and rear sprocket mounted on the rear axle.
Side shot of the completed frame.
Fitting the motor and welding on motor mounting plate.
This picture shows the jackshaft needed to transfer the power to the other side of the rear tire. Looking back, I could have shifted the engine over by an inch or two, and eliminated the jackshaft altogether. I’m really not sure what we were thinking.
Also shows the cover I built for the clutch/chain at the engine, the hydraulic brake caliper, and horribly welded exhaust.
And finally the completed picture. Don't mind the miscellaneous parts/metal/soda cans strewn about. I was excited and wanted to drive it.
The bike handles decently. I won't lie, it isn't nearly as I had originally envisioned it, but I hope to correct that, with a smaller front tire, a proper front steering setup, and I hope to build the frame to enable a drive train without a jackshaft.
So let me know what you guys think of my little hobby/experiment! If anyone seems interested, I'll make sure to keep this thread updated with pictures of the new build!
Also, small word of advice; Don't ride a 150lb bike with a skinny bicycle tire up front when the roads are wet.
