FYI.....
A friend just ordered a small electric (120v ac) leaf blower on ebay and gave it to me. It's really small and I was able to take it apart and separate it from the electric motor pretty easily. The trick is to cut or chisel away the armature from the shaft and it will leave you with around 4 or 5 inches if shaft to work with. I picked up a couple of extra high speed bearings and now I have to make a bracket to hold the blower body and bearings. I have a lightweight 2" aluminum pulley which will be attached to the shaft and a 5" pulley that will go on the jackshaft to drive the blower. As long as the bracket that holds the blower and bearings is strong enough to hold it all together under load, I figure it will at the minimum force enough air into the carb to give a performance boost. It remains to be seen if this will actually create true pressurization or not.
We're going to bench test it with an electric drive motor and I'll put a low pressure gauge on the capped-off output tube to see if we register any psi when we get it up to speed. For a small cc engine you only need to generate a few psi. When I was hot-rodding V-8's we typically ran about 10-20 psi of boost, so anything up to 4 or 5 psi on a small engine should "theoretically" work.
The thing to consider when forcing air into your intake is to remember that carbs work with a vacuum or venturi principle. If you do get true pressurization, gas will be forced back up the carburetor, fuel bowl, or vent tube unless you pressurize it as well. The way to do that is to tap off a small line from the blower to a fitting you put on the vent tube, or you can pressurize the gas tank by running the pressurization tube to the gas cap, all depending on what kind of carb you have. The main idea is that the air pressure in the carb and the incoming air have to be equal or gas won't flow into the engine.
It'll be a couple of weeks before we get around to testing whether we can build up workable pressure with the leaf blower parts because we're still in the middle of fabricating our chassis. The leaf blower cost $14 and the bearings were under $10 at American Science & Surplus so even if it doesn't work it will be an interesting experiment. Everything will hinge on whether the leaf blower can actually generate couple of psi of boost or not.
Oh BTW..... in my previous post I noted that NOS systems made by Holley for single cylinder small engines was cost prohibitive ($680). Since then one of the guys found these cheapo one-shot disposable systems on ebay for real cheap. We're ordering one just for giggles to see how they work. They're supposed to give you a 8 second power shot of NOS.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=220136864299
Will report back later on whether the home made supercharger and the NOS system work or not.
