Hi! In urgent need of help with an engine swap.
mojicamiguel7477
Very interesting. There are two of these "Eagle II" karts now on the forum. I have never heard of them before and don't know the brand or manufacturer's name but they may be fairly common in real life.
https://www.diygokarts.com/community/threads/trying-to-indentify-this-old-kart.51060/#post-629789
If you can find words on the kart that says "Inc." or "Co." let us know what else it says.
You can always "give it a reach around" and operate the throttle with your arm behind the seat. :cornut:
Keep the Briggs and fix it up!
Otherwise, this video should show how it is on most Honda and clone engines. You can pull the throttle lever from two different directions, actually.. (from the rear and from the side near the carburetor)
Thank you for your helpful response. I am looking around to find out who manufactured it.
Atlanta, GA
Looks like an "Eagle II" kart. No idea who manufactured it. In my mind it literally makes no difference, there are not parts specifically available for it anymore. But most if not all available generic parts can be made to substitute or replace what it came with.
I was actually saying his is the 2nd one we've seen as of late.
Shut up, you.
We want to know... Everyone who comes here wants to know all the nauseating info in excruciating detail because it matters. Or they think it does... Heck, I want to know the ID of all the junk I drag home.
Most of these karts are domestic U.S.A. made and we should be proud.
:roflol:
Jimmyjoe
Hey everyone, I joined this forum searching for advice on how to engine swap a Briggs and Stratton Fun Power gokart with a GX160 from a pressure washer. Can it be done? Let's keep this forum alive.
Anything is possible. But is it theseable to do so. Would say yes. Had a briggs 305 cc genotator engine with a tapered shaft milled it down cut a key slot. After about four or five hrs a 3/4 “ clutch fit tight with little vibration using a grinder and a dremil tool and a 3/4” rench. Yes if you think ig will work anything is possible.
DimaMakuha
Not everyone would take the time to hand-fit a clutch that precisely — definitely shows that with enough determination (and the right tools), you can make almost anything work. Curious how it’s holding up after extended use?
Jimmyjoe
Haven’t had any issues with the clutch or the shaft. Little to no vibrations from it. Wasn’t to much trouble removing the clutch and changing to a tourque converter on a new cart i made. Used that clutch for about six months.
Kinda off subject but the carburetors for that style brings have had nothing but trouble. And nothing but trouble with the engine itself. Would push my kart to 55 mph.
Here is the go-kart in question.
Found out who the manufacturer was:
Minat Inc.
115 East Front St.
Annawan, IL 61234
Their brand label for this kart appears to be "U.S. Eagle Series". This info was found on a product recall on the CPSC site.
