HF rpm Confusion
budd0413
So after spending a whole afternoon searching this forum I am more confused than I started. Everyone has their own opinion of what a hf motor can handle with or without mods.
Some people say just yank off the governor and you can run 5200rpm on stock internals. Some people say throw in 18# valve springs and you can break 6000 if you are not scared of being torn apart by your exploding flywheel. So the purpose of this is to spark someone to make an end all be all, perhaps a sticky about what the real,safe working limits are of a hf 6.5 hp motor.
so heres what I would do to my hf motor if I had one. Basically performance basics from agk.
Remove the governor
install 18# or better valve springs
less restrictive exhaust and intake
tune the carb, they suggest a #90 main jet
aluminum flywheel
aluminum connecting rod
So assuming all of this is done, is this motor going to last running wot or at like 6 grand for any extended amount of time, or does this just ready the motor for the occasional 6 grand bump?
sayre315
Rupp enduro
Oklahoma
if you get one of the honda aluminun flywheel and ARC rod then it should hold up to around 7-8000
Pa and Corby
3203 yerf dog & Appco
Ohio
I am doing the same mods to my clone, minus the aluminum flywheel and rod. and I ve done a bunch of homework on it, the engine will handle the rpms no problem, just keep the oil changed. Ive been told it will rev to 5200 rpm's but the exact rpm isnt that important is it? you will have to but a stiffer spring in your tav so it engages at a higher rpm thats all. P.S. Ive done averything except removeing the gov and adding the 18# springs but thats next! also there are a few web sites that specialive in clone hop ups, i have them somewhere here? let me know if ya need them, I spoke to them they are real helpfull!
oscaryu1
A guy running a Clone shattered a flywheel at less than 6,000. And they retorqued everything before doing this. Lucky it was running on a stand at that time.
Remove the governor
aluminum flywheel
Flywheel and rod first, then come the other mods. If you're a safer like me.
Scout
Nutjob
Indiana
Anyone have anything new to add? After running mine a couple times I realized the governor sucks and is in no way smooth.
Scout
Nutjob
Indiana
Wait, the surging comes at WOT. Idle is fine. When I drove down the street the other day it would rev up and die, rev up and die, etc. Last night I disabled the governor and next week I will order a flywheel and maybe some other goodies. (More money... :rolleyes: )
Russ2251
AZUSA:Powered by LAWN-BOY
Clean the carb and check float level. High speed jet is possibly partially blocked/clogged or is wrong size.
Engine should run perfectly in stock configuration first before making any mods such as flywheel and other goodies.
You would't buy new windshield wipers for a broken windshield, would you?
Russ2251
File out the jet
OUCH!!! Wire gauge drills would be a better choice.
"**** EPA idiots"
I found one or two
crazycart
RedNek Engineering
MINNESOTA
Russ, are those bits from northern any good? I got a big kit of like ryobi ones and they all are snapped/dull already.
