HF 6.5 vs Tecumseh 5.5
Which should i use?
  • Total voters
    20
novaracer
you can make a clone fly cheaper than the tec. my son has one with ported and polished milled .075 ss valves bored carb and nr racing 252 cam 26 lb springs billet rod and flywheel its real fast on a mini bike. mine has a 27mm big valve head 274 nr cam 22mm mikuni 55lb springs 1.3 parsons rockers 3stage pipe flat top light weight piston file fit rings and its just nasty and tries to kill me every time i twist my wrist.
redsox985
PA
What did that cost you?!? And for whatever it cost, I'm sure you could pick up an older 125 that puts out in upwards of 30HP with a gearbox.
Bluethunder3320
the clone valve train, block, and tank i like about clones. the carbs and exhaust really could be better.
novaracer
Perhaps. Some of us (most?) would rather not deal with Chinese crap.
lol hey i like somthing as a base and build it to fit my needs. yeah you can do that with a briggs animal or even a briggs 305. but they cost to much and aftermarket parts cost too much. i only use the block crank and side cover oh and the head casting. the rest of the parts are all made in the usa down to the head gasket. and as long as you dont need to make over 17hp in most cases a clone is cheaper as long as you have half a brain. hell tom even has all kind of video tech stuff on karttraxx:roflol:
redsox985
PA
But what does all of this cost you?? Have you actually totaled it all up?
