HF 6.5 vs Tecumseh 5.5
Which should i use?
  • Total voters
    20
B man
Tecumseh FTW!
Oliver springs,Tn
it did already have a throttle setup to....i may use it,but only if i can repair my old throttle setup. would a bike shop be good for throttle cable?
B man
Tecumseh FTW!
Oliver springs,Tn
ok and one last thing. i have a locking collar? on the rod that leaves the foot pedle. it was stuck and i had striped the set screw trying to get it out. i tried to drill the screw out with a bit but even after doing that it wont come off. i even tried to knock it loose with a hammer. no luck. it looks like the shell of the screw is still there. my question is where can i get a new one? because im thinking of cutting it off with my angle grinder.
JHen
what you need is an easy out. You can get them at auto parts stores
You stick the business end in the hole your drilled and turn it like you are unscrewing the screw. These are left hand threaded so they will dig into the screw until the friction of the easy out is greater than the force holding the screw in, at which point you will start to unscrew the screw.
Also, PB Blaster or somethign similar will also help. Spray it and let it soak in for like half an hour, then have a go at it.
JHen
Well, you said there was a shell of the screw left. Did you drill it completely out, no threads left in the hole?
dave1701
Good for 100,000 Miles
MICHIGAN
I would choose the Tecumseh. Mine is reliable as hell, and I would rather not get a clone, just because harbor freight stuff is generally crap.
