HF 2.5 hp throttle linkage setup?
Dbikes
Just got one of the 2.5 motors from Harbor Freight for my son's minibike. Do you guys have any recommendations on how to hook up the throttle cable? I did a search, found some info on how to do it on the 6.5 clone, but not much out there on the 2.5. Thanks.
robbie
Osceola, Missouri
I have one on a mini bike and one on a go kart. Use a long cable that goes back behind the carb then curves forward to the throttle arm. To make a stop bracket for the cable housing end, I welded a piece of steel onto the frame and drilled a hole in it. The cable goes through the hole easily, but the housing stops at the bracket.
The cable is connected to the throttle arm with a piece of hardware that's commonly used with RC airplanes, called an EZ-Connector by DuBro products. They make them for other purposes, but I have a lot of RC gear so I used one made for airplanes. I also should point out that I used the metal retainer rather than the nylon type. Look up the DuBro product, then see if you can find one somewhere. Or go to a hobby store and get one intended for larger airplanes.
Remove everything throttle-related except the actual throttle arm itself. Go to the hardware store and get a spring that will pull the throttle back to idle, and attach it to the cable connector on one end. Attach the other end of the spring to a screw or a hole somewhere forward of the throttle arm. You don't want a super stiff spring, but you can't use the governor springs that come with the engine. They're too wimpy.
If you need to see a photo of my assembly I'll be happy to post one.
Make sure you get rid of the governor on this engine. It's a small engine, so you'll want everything it can give you. Also, what kind of gear ratio did you use? We're using 10.2 to 1 with eleven inch tires, and it works great. You may also want to build a custom exhaust. It will increase the power noticeably, if you make it flow more freely than the stock exhaust. I used a cylinder-type muffler commonly found on old Briggs engines, welded on the end of a 3/4" I.D. pipe about 30 inches long. It sounds like a Harley, and it adds noticeable power.
robbie
Osceola, Missouri
One other detail on the throttle linkage. Install one return spring on the throttle arm, and another one on the hand control. Don't make one spring do the work for both ends. It will work better if you put some spray lube in the cable housing.
Dbikes
Robbie - What you described sounds like what I want to do. Pictures would be great. I just have a temporary L bracket with the cable mounted directly to the hand lever right now. I have not removed the governor yet, but plan to. I running the stock clutch and sprocket the came on the doodle bug. My son only weighs about 50lb so it seems ok on a flat road, but I think it needs to be geared a little lower for off-road terrain.
robbie
Osceola, Missouri
I'll take a photo for you in the daylight tomorrow.
What's your ratio? I used a jack shaft on mine, otherwise the rear sprocket would have to be bigger than the tire. I weigh 240 pounds, and that bike carries me at what feels like 20 mph on a rough gravel driveway with hills, even geared down to 10.2 to 1. It's a heck of a bike.
Dbikes
Stock DB30 clutch and rear sprocket, 72T I think. I'm thinking a jack shaft my be my next upgrade.
robbie
Osceola, Missouri
I looked up that clutch, and it looks like it has 11 teeth, for a ratio of 6.54 to 1. With a 2.5 hp engine, that's a pretty low ratio for off-road.
I had my son drive our mini bike today while I clocked him with the pickup truck. His speed on gravel was 20 mph, which is about as fast as you'd want a kid to go on his first mini bike, I think.
What's your tire diameter?
Sorry, I got caught up in other goings-on today. I'll see if I can post that throttle photo for you tomorrow.
Dbikes
Tires are about 14.5" tall (145/70/6). 20 mph is plenty, but would like better take off power. Which jackshaft are you running on your bike?
robbie
Osceola, Missouri
I have ten teeth on the engine, 17 and 10 on the shaft, and 54 on the wheel. That comes out to a 9.18 to 1 ratio.
Assuming that you take off your governor and free up your exhaust and air intake so your engine can go 5000 RPM, your bike is set up to top out at 32 MPH. I'm not sure this engine is capable of that kind of speed, especially with stock air cleaner and exhaust. It would just bog down and burn the clutch. You'll notice a huge performance increase if you change to a higher ratio.
Check out the forum for FAQs and articles. I just wrote an article with all the formulas for finding speed, RPM, tire diameter, or gear ratios. http://www.diygokarts.com/vb/showthread.php?t=9591 With the 2.5 engine, shooting for 18 to 20 MPH is perfect. At that ratio, my bike takes off quickly but does not peel out. If I were to gear my bike for better top speed the acceleration would suffer. If I gear it for lower top speed there will be no gain in acceleration because we will get into the peel-out zone, which can cause instability on gravel anyway. So I think gearing for 20 MPH is just right for a kid.
robbie
Osceola, Missouri
I'm having a terrible time posting the photo of my throttle linkage. First I lost my internet connection for most of the day, and now I can't find the USB cable for the camera. Do you still need to see it, or did you get yours working already?
Dbikes
I think I'm good. I have a temporary setup right now that I'm pretty happy with. I do need to make a trip to the hardware store for some more parts, so I can replace the paperclips and bubblegum. The engine runs great, but I definitely need to get a jackshaft to adjust the gear ratio. That's my next project. Thanks for the help so far and Happy Thanksgiving.
