rgvkid
Charlie Don't Surf!
Im having a tough time cold starting the degoverned 2.5 HF engine. I have to pull it like 10x. So far it only has about an hour running time on it. Im not sure which screw to mess with on the carb. When i first started it, it started right away. been test running the kart off and on and its been sitting for about 5 days since the last time i ran it.
After about 6 pulls i adjusted the idle a bit to get it started and had to play with the choke off and on to keep it running until it warmed up enough to run on its own. Maybe its just breaking in and needs adjustments. Im not sure if the air filter im using is to small. Its about the same cubic inches as the stock one. The gas is new 89 octane also. Once i run it a bit it doesn't take as many pull to start up again.
Any tips would be appreciated.
Thanks.
Thanks.
