chance87
i believ i have trail master its a gy6 motor i had to get a new harness because the other was shot.i but i cant figure out how to wire this resistor into the autochoke its only 1 wire any advice would be appreciated
thnx manI have no idea, but if you wait around some one will chime. See you found the right area!
Just take the old one off. If there's not a place to connect the new easily, you can cut the wire and splice it to the old wire. Just use a good connector and preferably a water-proof sheath over it (the kind that you slightly heat up to seal). Should work just
splice it into what???wiring diagram says 2 wires one from voltage regulator and one from autochoke?Just take the old one off. If there's not a place to connect the new easily, you can cut the wire and splice it to the old wire. Just use a good connector and preferably a water-proof sheath over it (the kind that you slightly heat up to seal). Should work just fine.
there was no place for it on new harness old harness someone tore apartit looks to me like you need to just unplug the red wire that come off the auto choke the plug in the new one to where it was
