hey guys i have a question
Drfierce
i have an electra 43cc mini chopper and I'm planning on putting a 97cc Baja engine on it. i got a couch for it and it has 10 teeth and the sprocket on the tire is 28 teeth. do you guys think that will be to b=much for the bike to handle? thanks guys
ML-TOYS
long island, new york
First problem is that the wheel sprocket is not the same pitch as your clutch teeth.
I basically did the same with a 5.5 hp and used a 10t to a 64t
Drfierce
does that mean it won't work? what does the pitch mean
.... What ML said.....
And no.... 2.8:1 is not a good ratio at all.... Need closer to a 6:1...
And what's a "dually".... 2rear tires??? Then it's a trike....
Drfierce
it has 2 tires that are attached to each other. not a trike a dually mini chopper
Poboy kartman
Senior Moments Member
White Settlement Texas
WAIT!!!! One tire in the front.....two in the rear....that's a trike!!!!! (Yours just happen to be closer together! )
JK.....Welcome to the forum.....and yeah.....gear ratio is fubar....
Drfierce
Drfierce
well what is the lowest ratio that i could use and be safe without destroying the clutch or something do you guys think
No higher than 5:1. What you are proposing is NEVER going to work. Google chain pitch and you will see what ML-toys is talking about. It is basically the distance between peaks on the sprocket, and/or links in the chain
