outcrydrummer
KART ART
Ahhh, timing!!!
Are you sure you have an 8° key? Stock timing is around 24°, so 8° should put you right there. UNLESS, it was installed backwards. I'm not sure it would even run that way, and certainly not anything close to "normal", but it might.
I would just quit jacking around, pull the air cleaner, hit the carb with brake or carb cleaner and pull the cord. If it starts immediately, there is a carb problem.
---------- Post added at 05:10 PM ---------- Previous post was at 04:56 PM ----------
.003 is MORE COMMON, especially on engines that start on the first pull.
Lash is at .003 right now. I initially set it at 3 then moved to 0 lash and now back to 3.
Ill have to check out the carb. I wouldnt have thought installing a longer rod and stock lift cam would have changed anything enough to require different jets etc for a previously good working carb setup.
---------- Post added at 07:16 PM ---------- Previous post was at 07:14 PM ----------
Yeah its an 8 degree key
Installed so that it advances the flywheel clockwise per instructions
