outcrydrummer
KART ART
I installed the arc .20 rod and the mod 2 cam today. Took everything apart.
Everything went as planned.
Torqued rod to specs following the torque procedure from arc
Had proper oil clearances for rod
Assembled the block with 0 last at tdc and clayed the piston for valve clearances.
Had lots of room. Piston was .030 in the hole and I had a minimum of .080 clearance from piston to valves with no head gasket.
So I installed the thin metal .010 head gasket and put everything together.
Set valves to 0 valve lash
filled with amsoil 10/30 full synthetic
So now engine is hard to start.....had to open idle stop quite a bit to even get it started. It starts and runs and idles fine but I hear considerably more top end noise now.
I am 100% sure the cam was lined up
100% sure the rod was torqued and all the internals are where and how they need to be.
I've reset valve lash twice since the first start up and it's still the same deal.
Previously engine would fire on first pull with choke on. Now its 8 to 10 pulls and it will start.
I think I'm just to involved at this point and can't get my head wrapped around it.
Any insight???
---------- Post added at 05:27 PM ---------- Previous post was at 04:50 PM ----------
Not sure if i said this but to clarify it runs fine will accelerate and hold idle etc.
Issues really are more noisy now and hard to start
Any insight???
