Hemi Predator issues (sort of)
outcrydrummer
KART ART
Greensboro, NC
I installed the arc .20 rod and the mod 2 cam today. Took everything apart.
Everything went as planned.
Torqued rod to specs following the torque procedure from arc
Had proper oil clearances for rod
Assembled the block with 0 last at tdc and clayed the piston for valve clearances.
Had lots of room. Piston was .030 in the hole and I had a minimum of .080 clearance from piston to valves with no head gasket.
So I installed the thin metal .010 head gasket and put everything together.
Set valves to 0 valve lash
filled with amsoil 10/30 full synthetic
So now engine is hard to start.....had to open idle stop quite a bit to even get it started. It starts and runs and idles fine but I hear considerably more top end noise now.
I am 100% sure the cam was lined up
100% sure the rod was torqued and all the internals are where and how they need to be.
I've reset valve lash twice since the first start up and it's still the same deal.
Previously engine would fire on first pull with choke on. Now its 8 to 10 pulls and it will start.
I think I'm just to involved at this point and can't get my head wrapped around it.
Any insight???
---------- Post added at 05:27 PM ---------- Previous post was at 04:50 PM ----------
Not sure if i said this but to clarify it runs fine will accelerate and hold idle etc.
Issues really are more noisy now and hard to start
Why zero valve lash?
---------- Post added at 05:00 PM ---------- Previous post was at 04:59 PM ----------
As things heat swell, the valves won't close all the way. That's the reason for the space.
outcrydrummer
KART ART
Greensboro, NC
Zero lash is pretty common actually.
the engine gets hot and actually creates more lash. Check a predator cold and then hot, youll have more lash hot.
Bbqjoe
Banned
Location, Location
The great Wazoo says:
When you had your spark plug out, you dropped it, and forgot to reset the gap.
outcrydrummer
KART ART
Greensboro, NC
Yeah it wants 32 degrees.
I have an 8 degree key in it. I bought an arc flywheel but i got sent the wrong part number so im still using my stock flywheel.
outcrydrummer
KART ART
Greensboro, NC
Well the timing question got me thinking.....
Stock is 20-22 degrees so im at 28 to 30 and the cam wants 32 degrees.
It could be the lack of timing causing the hard start.
Now the noise must be another issue......im gonna pull the side cover tkmorow morning and see if anything looks askew.
Randy H
Anyone have a ballpark idea of my new static compression with the piston .030 in the hole, .010 gasket ?
Just curious
If my calculations are correct it should be 137.73597 approximately. Need to know the barometric pressure and the airspeed of an African Swallow in your geographic location to say for sure.
Ahhh, timing!!!
Are you sure you have an 8° key? Stock timing is around 24°, so 8° should put you right there. UNLESS, it was installed backwards. I'm not sure it would even run that way, and certainly not anything close to "normal", but it might.
I would just quit jacking around, pull the air cleaner, hit the carb with brake or carb cleaner and pull the cord. If it starts immediately, there is a carb problem.
---------- Post added at 05:10 PM ---------- Previous post was at 04:56 PM ----------
.003 is MORE COMMON, especially on engines that start on the first pull.
