Piston, crank, connecting rod, camshaft installed...
Piston tool didn't get the top ring. I manually compressed it with my finger nails and finished installing that way.
Rod bolts lubed and torqued, again.
Crank shaft and camshaft markings aligned.
Let's see if I can measure lobe to cylinder clearance, then I'll put the side cover on and see if I'm 0.005" in the hole like I expect.
