yes tyler, your piston only has two lands or ring grooves. kyle was it? to make a 4 into 2, ditch the cam, pushrods, lifters, head. get a block of aluminum (easiest material if you can't find a donor head that will fit)make a nice symmetrical dome, drill and tap for sparkplug. cut say 1/4" to 3/8" in each side of the cyl after measuring similar displacement engines, make sure they are staggered. one higher than the other. you could stay running regular oil in the crank i guess. weld or bolt on a reed rig and affix the carb.
