I decided against the 2.815 Bore.
If I hadn't already purchased the 3.328" Rod, I probably would have a 220cc in the making.
But since I don't want to pay for another rod or cut the piston, I will stick with the 2.756" stock bore.
I am planning on the bigger intake valve if P2V clearance allows, which I think it will.
While I'm waiting on the NR 1.2 roller tip rockers,.... here is the valve lift with the stock rockers vs the 1.2's. I used 1.05 :1 Ratio for stock. I've heard anywhere form 1.0:1 to 1.1:1 for stock ratio.
I'm not sure that 0.050" lift overlap is important, but the ratio rockers add a few degrees of 0.050" overlap. from about -1 degree overlap to about 4 degrees of 0.050" overlap. Increase of about 5 degrees.
