help..
9800 GTX
Bent axle
ok, i have a go kart but i kind of wrecked it and i bent the solid steel axle :oops:
i need to know if i should just get a new frame or get something to heat up the axle hot enought to bend it back.
if im gonna heat it up, whatever i use needs to be under 100$.
the axle is 1" thick i think.
KieranM
Doin It!!
Kilkenny, Ireland
unless you have seriously good equipment you wont have a hope of bending it back to shape, If you did bend it back into shape chances are that it will still be out of shape.
Even if you think it is only bent a little bit, When it gets up to speed you will notice it
Any chance of just getting a new axle it would save you alot of bother
anderkart
Surprise Arizona USA
If you post your bent axles exact diamitor and length, we might be able to find you a replacement in the $30 to $50 range from an online parts supplier. Also include if your rear wheels are secured by threads at the end of the axle or not.
t0x1k
Vroom
South, NJ
My kart axles bent on both sides a good 1/4" out of straight and I can't tell at 35 mph.
Just get an acety torch and heat it up red hot and smack it with a big effing hammer til its straight enough.
Rickracer
RM250 Race Kart Driver
Kissimmee Fl.
Like Anderkart said, post up some specs and we'll find you a replacement, if you heat it up and bend it back, it will be weak in that spot, and chances are you're not gonna get it perfectly straight anyway. Might get you by for a while, but the right way is to just bite the bullet and replace it. :cool:
9800 GTX
Bent axle
the axle is 36" i think and it has threaded ends, but i dont even know if i can take the old axle out and put a new one in
Kaptain Krunch
Pro Junk Collector
vermont
oh, so its one wheel drive? Can you weld? If not i would get a Big Hammer and try to get it straight. a picture would really help, there may be a simpler solution.
