Help!
ypgaming
Nonya, Seattle
Hi peoples, me and my dad are trying to build a go-kart from nothing, but we need help. what type of metal should we use? and what engine?
we are starting out making a derby car. then, we will progress into a go-kart. please help? :surrender:
BigWes
Alabama
You can't be serious
---------- Post added at 05:48 PM ---------- Previous post was at 05:48 PM ----------
...do you guys even have a plan?
bthompson224
DFW
Agreed. You need to do some research and get some plans. If you are asking this, I'm gonna bet welding is out of your scope. Can I suggest you get a frame and start there?
JTSpeedDemon
2019 Build Off Winner!
Texas
I don't know if or when KartFab will chime in, but he has FREE go kart plans on his website: https://kartfab.com/go-kart-plans
As for the engine, get a Harbor Freight Tools coupon and get their Predator 212cc 6.5 HP, or the 3 HP 79cc if you don't want a ton of power.
BigWes
Alabama
He needs to check out kartfabs website and watch all his you tube videos. But first the dude needs to do some research before buying anything. Didn't you read what bthompson224 posted? Huh? He may not want a predator. He may want a gas turbine or a Mazda rotary. Let him figure it out...
JTSpeedDemon
Texas
bthompson posted while I was writing mine, so it didn't pop up until I posted.
Gas turbine or a Mazda rotary?
I like your ideas....
Now if he could figure out how to stuff a Ford FE 427 on a kart...... :auto:
Then he'd be cookin'.
BigWes
Alabama
He could do that...then he would have this...
JTSpeedDemon
Texas
Well is that a bad thing???????!!
I am a huge fan of Cobras and AC Aces, regardless of powerplant, they just look wicked.
There's an Aussie karting website called www.helmetkarts.com, and you can buy 3/4 scale Cobra, and retro Corvette bodies!
Anyway, let's not derail the thread any further. :oops:
Round, square, and rectangular tubing is what is generally used in go kart construction. Round tubing has a bit cleaner look, tends to be a bit more of a pain to build with and usually requires a tube bender. Pipe benders do work okay bending tubing, however with tubing be measured by outside diameter, whereas pipe is measured by inside diameter, pipe dies don't always fit the greatest for tubing.
1" tubing with .125" (1/8th") thickness is a good start. A rule is, a larger diameter with a thinner thickness is usually stronger than a similar size diameter with thicker walls, plus you can sometimes save on weight. Keeping weight to a minimum is paramount with go karts. Mild steel is probably the best metal to build a go kart out of. Chromoly (Chrome Moly) is a pain to work with, as it usually needs to be pre heated and post heated to be welded as to prevent cracking of the base metal and filler.
Other metals (aluminum) can be used, however, you need to be well versed with working with the stuff.
