Help!
nissinator
kansas
ok so my 5hp B/S engine wont start but...i start with drill....when i have it in choke and i use drill on high speed...im just getting flames out of the exhaust....and when i have it on run nothing happens....please help
Jake.B
California-USA
Well did this just start, have you added any mods or took apart the engine? Sounds to me like timing, sheared flywheel key, or a stuck/malfunctioning valve.
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
I agree. If the key is sheared, the wheel is going to be out of alignment with the ignition coil. This means it's going to fire at the wrong time. That's probably one possibility.
Also, what kind of drill is it that you use to turn over your engine? Must have a helluvalotta torque.
If I didn't know better I'd say you valve timing is out & your exhaust is opening on the power stroke. Have you had the engine apart?
A sheared flywheel keyway is very possible but the result would be erratic, valve timing would be more regular.
nissinator
kansas
ive had the engine apart like 20 times now this is the only time ive rebuilt and have it not start....the valves arent stuck and are working just fine....ive checked my timing gears and my key isnt sheared...i made my own out of much better material
nissinator
kansas
Yep just did actually tore apart whole keyway in crank so had to replace that an,it still wont start?
